Howdy. Anyone have any ideas as to why my steering is catching when I turn sharply at low speeds? It catches for a second with somewhat of a pulsing sensation and then the steering is fine.
One other thing you might check is the clamps on the ends of your tie rod. If they're not positioned correctly, they will contact the Lower Control Arms in sharp corners which you would normally only see at slow speeds.
Thanks, Dave! The torque was checked. 2 were barely loose (including the one in photo), but all (axle mounts) have rust stains so I suspect the metal sleeves in the OME bushings. Frame mounts are clean.X2, also re the photo, checkout the rust stains on the lower arms where they meet the axle, this normally indicates the bolts are slack allowing the arms/bushes to rub and wear the axle mounting holes oval.
regards
Dave
