Steering Arms
I installed the steering arms today and when I connected the pitman rod end to the pitman arm, the hole in the pitman arm is a larger diameter than the pitman end. Can I remedy with placing grade 8 washers between the nut so I can tighten the pitman bolt to specs?
Thoughts, pls.
What steering arms? More than likely they are reamed for a larger tie rod end, time to upgrade.
They are the upgraded steering arms, short and long with tie rod ends. When I connected the tie rod end for the pitman arm the bolt is too narrow for the pitman arm. When I tighten it down the pitman end compresses down to the end threads and the nut is still not tight.
What do you mean upgraded?? Upgraded from what? I was thinking of trying to find some steering arms off an 81/40 when I do a mini truck ps upgrade . Not sure yet how hard these will be to find.
I bought stronger ones from BTB products with new tie rod and pitman ends.
The stock ones are in decent condition with exception that they can't be adjusted becasue of their age. All my tie rods ends needed to be relpalced so I went ahead and repalced the rods.
Thoughts, pls.
So......
Are you talking about a saginaw conversion pitman arm not working with the drag link end?
What kind of steering are you working with here?
So......
Hey Poser.
Yes, that is exactly what I'm talking about. The steering box is a signaw box with the oriignal pitman arm that was used for the conversion by the PO.
Typically what is used is a Jeep pitman arm on the steering gear with a Jeep drag link end going into that Jeep pitman arm. Then there is a custom drag link made that has the Jeep drag link end female thread on one end and the Toyota drag link end on the other. These can be procured at many a Land Cruiser shop out west. I am pretty sure that MAF and BTB offer larger diameter, stronger rods, compared to the stock piece.
I would not stack washers to make things “ fit”. It is your steering. Get the correct components and do it right.
Good luck!
-Steve
So you just need a different pitman arm...
Marksoffroad.com
Cruiseroutfitters.com
Downeyoffroad.com
Any of these folks will have the pitman arm you need.
:beer:
