Steering arm preload help needed...
Bozeman, MT
Howdy,
Got into my knuckles last night. When I reassembled them however, my preload was nearer to 10 pounds before I saw the knuckle turn, instead of the factory spec of 3.9-5lbs. I know I need to add more shims then but I had a few questions.
First off, there were only two shims on top with the arm, a thick and thin. Then there was only one shim on the bottom. A thick one. These are obviously not working once I got it all back together, so I am back to square one.
How many shims (new with my kit) should I use as a starting point to get my preload corrected? I have thick ones and thin ones too. I was thinking Two thick and two thin ones?
Also, the arms are a beast to get in and out, is there an easier way to drive the arms in and out to adjust these things? I am using a punch and Hammer.
Thanks in advance, I appreciate it!
REZARF <><
You can do the trial and error and add a shim top and bottom of the same thickness. Assuming the knuckle was set up correctly to begin with.
You should not add to either top OR bottom, but both at the same thickness.
GL
Ed
almost every cruiser i've done has taken one thick and one thin on both top and bottom. also, are you spinning the rotor a few times before checking preload? you need to get the grease on the bearings spread out before checking.
My impressions from doing this recently for the first time, with lots of time reading about it and asking questions here:
10 lbs is perfect. If you're running larger than stock tires it needs to be a little tighter than stock. I've heard recommendations of 12-14 lbs.
Equally important is centering the axle shaft so you don't ruin the inner axle oil seal. The FSM procedure using the SST allows you to distribute the shims to account for casting variations in the knuckles. This was done at the factory of course, hence the recommendation to replace the shims exactly the same way they came off. If you wanted to add more I'd just add a thin one to the top - adding to the top is the factory recommended procedure.
If you 've mixed up the shims and don't know how they were arranged from the factory, you need the SST to start over.
Lastly there is more to it than "thick and thin". The OEM shims come in .1, .2, .3, .5, and 1mm thicknesses. I don't know what's in the aftermarket kits - all .1mm?
Thanks, if 10lbs is good then I am fine. I was hoping that would be good.
So the fact that there was only one on the bottom arm isnt a big deal if it was set up like that from the factory?
And by the way, what is the SST?
Thanks Again-
Drew <><
If you kept the shims in the factory configuration then you are all set.
Toyota Special Service Tool 09634-60013, "steering knuckle centering gauge" is used to center the knuckle/axle shaft by giving you a guide to pick the correct shims. In the factory service manual procedure you measure the difference between the center point of the knuckle and the center point of the axle housing with the tool installed, then subtract 0.3mm from that value and use that as the bottom shim thickness. I think mine were 1.2mm and 0.9mm on my Pig with the FJ60 knuckles I put on.
You also use the tool to measure how much total shim (top + bottom) is needed to get the proper preload, then subtract the bottom shim thickness from the total to get the top thickness. Average total shim thickness appears to be something around 2mm - using Ige's method you will get 2.2mm if your thin shims are 0.1mm and your thick shims are 1mm like the factory thick ones.
You only really need the tool if you are changing to new knuckles. 99.9% of the time you should be fine with your old shims if you're keeping your old knuckles.
:cheers:
i dont want to hijack here, but i have a simular problem i started my knuckles this weekend too. and i had one thick and one medium shim on top and just one thick on bottom and when i put it back that way it had about 5lbs on the scale i wanted it a little tighter so i swapped a thin shim for the medium one and its now at about 8lbs does that sound good enough, i am running 35 in. tires. and when i went to one thick top and bottom i got around 12lbs but it seemed to stick or catch here and there as you pulled it ?
Also i noticed that IGE posted about turning the rotors a few times, i was under the impression that you checked it with just the knuckle mounted and bearings in and no felts on yet. is it supposed to be all asembled with axles and felts and everything when you check it. if so boy did i screw up :doh:
PLEASE help, its my first closed knuckle!
8 lbs is a little light for 35's but probably ok. You tested the preload in the proper configuration, without the felt seals or axles/spindles/hubs/etc.
If you feel it catching it's probably too tight, or the bearings were not well greased. Ige's advice was excellent as usual, but I think she was thinking about wheel bearings and meant to say turn the KNUCKLE a few times, which I certainly agree with.
I think you're all set, but if you need to convince yourself, turn the knuckle back and forth a bunch of times, remeasure the preload, and if you want to go to 10-12 lbs get a set of OEM Toyota shims and change the thickness in 0.1mm increments until you get what you want.
Thank's yooper, i thought i did it right. i may mess with it and re-grease the bearings, i am in no hurry i want it done right and its been apart for about a 2 month's while i got all the parts and had birfs treated. THANKS AGAIN!! and hijack over.
