steering, 3 part question
Decatur, Ga
When turning at a intersection, left or right, front end 'pops' and 'creaks'. Why? Is this normal? Is it the ball joints or steering box? Need a lube job?
Drive down the street, road curves to the left, I turn the wheel to the left but FJ keeps going straight. I start to poop. Turn the wheel a little more to the left and I keep going straight. Telephone pole coming right for me. I look up brakes and stop about 10 feet from pole. I start to go again and steering if ok, even though it still 'pops and creaks' at the intersection as I turn.
Something up in the steerig box? Broken teeth on the gears in the steering box? Steering box does leak, and until about 3 weeks ago, when I checked it for the first time, it was bone dry to the bottom, due to previous owner neglect.
Alignment. Can any shop that does alignments do it, or should I call and ask before taking the time to just drive in? Is alignment dont on the tie rods, or do they get into the steering box?
Thanks
If it were me, I'd have it towed to an alignment shop. You're dealing with life and worse here...Not normal, probably worn out tie rod ends, slipping drag link, used up steering box, or more than likely, all three. Any alignment shop should be able to handle this. Neither pooping or popping are acceptable!
