Startup Misfire
North Front Range, CO
I have what sounds like a misfire for the first seconds of starting up when motor is cold. Goes away in less then a minute. Any ideas or how to diagnose this when it only lasts seconds?
Thinking its a distributor or injector issue.
Mine had similiar symptoms at startup and was the early stages of a headgasket issue.
Have you checked your spark plugs? SPark plug leads? and igniter? If all that passes I would check distributor cap and rotor. It's cheaper and easier to get to than the injectors. Good luck.
