Starting The 91 FJ 80 Reconditioning
Starting long over due 91 reconditioning. All stock running great. Just fixing rust. Post a pic after she’s done
Added some 1/4 inch G10 epoxy board to fill and strengthen things up. Not pretty now but she should buff up nicely, at least good enough
I would seriously consider cutting and welding.In a roll over which I have done.Your roof would collapse and the result could be fatal for you or others.
The steel under the top layer is all ok and fully intact. I have filled the area with layed up glass and g10. It is not just filled. It is actually structural and may even be stronger than original as this is how boats and planes are made. I have filled holes in the hulls of ocean going boats using this method. Still have some more lay up to do
