Starting problem when hot
The '91 developed a problem today it has never had. Drive it, shut it off, won't start. It cranks, but sounds like not firing. Let it sit for 20 minutes and it fires right up. Drive it 20, shut it off, won't start.
Fixed this before? Thanks
EFI Relay...exactly right. Thanks! Fixed.
There are 2 basic fixes; one is to get a relay that is HD. The more common fix is to upgrade the wiring to the relay. The problem and the fix only impacts the 3FE versions of the 80-Series. This fix has been well documented here on 'Mud so do some searching and you should find all the information you need.
-B-
