- Joined
- Aug 2, 2011
- Threads
- 3
- Messages
- 42
So after lurking and reading build threads for awhile i figure its time to start.
parts will arrive off and on over the next month.
A couple of things i have noticed everyone tends to use A LOT of steel thru out the whole building process. My self i wont be going this route.
As a Boat Builder by trade for almost 35 years i will use steel for my frame and base structure but for the Box portion of the trailer it will be composite.
As for using steel thru out i'm still puzzled by this one. Don't get me wrong you guys are building some great trailers here and your ideas and applications inspire me to build.
Simple math unless of course my long hand is out
ex: a 4x6 foot by 2 feet deep box built from steel. 1x1 say with a .120 wall for up rights (frame of box) and 14 gauge sheet metal. now this includes bottom,front/rear and flat lid. you need 80 feet of 1x1(1.43 lbs.per foot) , 88 sq. ft. sheet (3.125 lbs per sq.foot)
now here goes my math that weights out at 389.4 lbs.
this is just the box .
Now i can build this same box via composites exact same dimensions
structurally sound enough for what will be carried on top and inside for 170 lbs.
This is a weight savings of 219 lbs.
Unless i am missing something here that needs that much steel.
Is it perhaps related to longevity or damage?
or is it just the norm to build this way?
To me from a pulling perspective that's alot of weight.
But anyway i will take pictures as i go and post.
