starting issues
Kansas City
Looking for help with my 04 Tundra. Have had no signs of starting issues, driving home last night and made a stop, got back in turned the key and clicked once. Lost all power to dash. Waited 5 minutes and did the same thing. Took battery to get tested. Checked out good. Put the battery back in and started first time with no indication of struggle. Got home, turned it off and would not start. Clicked once and nothing? Any advice would be great!
I would say it is either the starter solenoid or the starter relay. The starter on the 4.7 is under the intake manifold and sucks to get to.
Thanks! It ended up being the ground wire from the negative terminal clamp. The brace that holds the battery down was loose and apparently moved the battery and pulled the ground wire making a bad connection.
