Starting issues varying with temperature
Minnesota
My 93 LC won't start in cold weather under 50 degrees Fahrenheit, starts perfect at 70°F, and starts but has really low power at 80°F and above, until the engine warms up a bit. Any theories on the cause? Is there an incoming air temp sensor? Thanks in advance for any thoughts you have, I have yet to delve into my manual.
**EDIT** Engine "cranks" at any temp, just will not start when temp is below 70 degrees F.
Starting? Is the engine turning over? or is the starter not functioning?
If the starter isn't turning over and no solenoid click is heard, tap your starter/solenoid with a hammer. Then try starting. If that's the case, a new set of contacts and a plunger should be in the works.
If you are hearing the solenoid click, then your battery is weak or the battery cables are loose/needing replacement.
^X2
X3. I had some weird starting issues last winter and when I replaced the starter, I didn't have any more issues. This year is was the battery that failed me.
Remember, if you go to the auto parts store and they test your starter, there's a good chance it'll test just fine even though it's actually causing issues. The battery test should be accurate.
The starter is like ~$130 for a reman'd Denso (IIRC) and can be done in about an hour or so.
Starter works perfect. I can crank the engine all day long. Eventually, if I crank it long enough, the engine starts firing on enough cylinders to start, but it takes A LONG TIME.
I would start troubleshooting the ignition system, plugs, wires, cap, rotor, coil, and igniter.
I have similar problem some time ago in other land cruiser. The question was a bad contacts in the starter. Open it clean it change the kit of starter and at least in my car say bye bye to the problem.
i've had this problem on my suzuki for as long as i remember... maybe the past 5 years or so... will start the first crank if temps are above 70... the colder it gets the longer it takes to crank... i just hold the key for 10 second bursts until it starts firing on one or 2 cylinders... then it eventually will catch on all 4 after 20 or 30 seconds
it's never failed to start on me so i've not worried about it, but i always just assumed it was sticky injectors... maybe it is the plugs/wires/rotors... i've always wondered but it's never not started so i've not been concerned with it... it can sometimes run poorly when it's really wet and humid out, so it probably is plug wires or something... it's an 1989 with 60k miles on it, so probably all original...
also usually it's good the rest of the day, it's only when it's been sitting overnight in the cold that it's really bad
good thing i have a strong battery that doesn't mind putting the work in...
I have to literally crank the thing over for ten minutes to get it to start. Eventually I'm going to blow up my starter haha
Starter will crank at any temperature, but the engine will not fire the cylinders and actually run unless the temp is above 70 degrees F.
OEM sparks and cables ? Some motors don't like others sparks ..
You need to check for spark when it doesn't start. Do you have spark? if yes, then fuel pressure needs to be checked. If no spark, then begin troubleshooting the ignition system as Wayne mentioned above.
Fuel+Spark=Start.
yea it never takes me THAT long in the zuk, but i got a feeling if it got as cold down here in NC as it does up there, it might
it takes me maybe 2 minutes on the coldest days
after it starts can you start it easily?
Here in MN, when the LC is running properly, it starts in 5 seconds on the coldest nights (negative 20 F).
Yes, if the engine is warm, it will start immediately. If the engine is cold, it takes forever to start.
in my research i'm seeing it could be a lot of different things...
could possibly be the coolant temp sensor.. i don't think those are too difficult to test, either... there are guides online...
When it finally starts, what does it run like? Does it immediately go to high idle and step down to 650 or does it go to 650 and stay there while warming up? Does it misfire or run poorly when it does start up?
my suzuki does misfire and run poorly for a good 30 seconds, trying to remember what the idle does...
It seems as if the air/fuel mix is wrong, when the engine is cold. If I rev it a bit, it seems to "clean out" and run fine afterwards. Its been a long time since I started it outside in the cold. I will have to try it and report back to let you know if it goes to high idle or not after startup.
