starting issues-solved
Waikato New Zealand
so glow plug circuit is fine and all working-bypassed all the ecu for this
no air leaks in fuel line and primer rock hard on starting
However its getting cooler here( only 5 deg C) but cold for us and my 1KZTE is exhibiting the exact symptoms of bad glow plugs -
-takes about 5 goes to wind over and splutters and coughs
-have to give it some throttle to get going and keep the high idle button on for at least 3 minutes
-lots of unburnt diesel blows out the exhaust once started
-unrelated but could be connected Over Drive wont engage till speed hits 105Km/hr regardless what the temperature the vehicle is running and for how long- once engaged the O/D behaves as it should until the next time the vehicle is shut down(really weird)
Im leaning towards a timing issue on the pump- just wondering if the engine coolant temp sensor the ECU reads could be the culprit?
Does this sensor also control timing or fuel on cold start?
Im going to pull the sensor tonight and test it just seeing if anyone else has had any similar issues with a solution other than spraying good old engine start down the intake cheers
update, checked the ecu - really easy at work to do this as we have some electrical engineers next door and all caps etc are fine- has signs of a previous repair
so next step coolant temp sensor-looks like a fun to take out sensor
Whats the compression like and how many Klms has it done? Low compression always rears its head on cold mornings, lots of grey/white smoke.
300,00ks
and compression could be bad, ill check this over the weekend, Im consuming a liter of oil about every 1500ks which could be a sign of stuffed rings/low comprssion
issue solved
dead temp sensor
cant believe it can affect the cold start , O/D shift point so much
all back to normal
I think I have similar symptoms. rough idle on cold, lots of smoke, when engine warms up , idle is fine and smoke reduces.
Could you tell me where to locate the temp sensor? and how did you check? thanks
