When I first got my carb back from Jim C and up until about 6 months ago, my truck woudl start up with a touch of the key and I would not have to touch the gas pedal.
Now, I have to pump 5-7 times, and keep the pedal floored while cranking to get the truck to start up. Once it starts it has some trouble idling until the temp comes up. It used to not do this.
I popped the top off the carb. All the seals, and passages are clean and look OK.
Timing is about 11 degrees below TDC (bb at te bottom of the window, which is allright for my altitude) where it has alwasy been/
Also, I was out wheelin this weekend. I didn't really have any problems other than when my truck was twisted up on an obstacle. The drives tire was stuffed, the passengers side was at full droop and the rear axle was sitting level. The truck simply died, adn would not restart (flooring pedal, pumping, full choke, no choke, etc) until I backed off the obstacle and dearticulated my front end..
This has me puzzled. About the only thing I can think of is that the frame might be flexing enough that it kinks a fuel line.
Any ideas?
Thanks!
James
76 FJ40
Any ideas?
Thanks!
James
76 FJ40
