starter sticking
charlevoix, michigan
I have had the stater on my 77' 40 stick/jam/wedge itself against the ring gear a few times. Normally I can stick it in gear and pop it loose by rocking the cruiser back and forth a bit. Last time I tried this it was really stuck, and being stupid I towed it and popped the clutch. Let's just say that the nose of the starter became dislodged from the rest of it. Now I need a new starter, but I want to prevent the sticking from happening again. What's causing the problem?? Also, the starter wants to engage when the key switch is in the accesories? position on the ignition. The bad part is, it wants to engage when shuting the cruiser off!! So, I have to be quick with the key so it doesn't close the circuit long enough to engage the starter. Any clues on that problem as well?
Hoping for some help for a newbie to the cruiser club.
Thanks ahead of time for any help you can give.
Bad ignition switch should be on your list to check, too - sounds like the solenoid was getting power when it shouldn't.
Ah, for the days of foot operated starters, like the one in my 1955 Chevy 3200...now that was a starter!
Kirk
Check that ignition switch. The original switch on my 78 got worn to the point where it was full of copper dust. It started doing unusual things in different positions. Sounds like part of your problem. The switch is easy to inspect, easy to replace, and not too expensive to replace.
Good Luck.
+1 great upgrade!
rogersfj401969 said:
get a starter out of an fj60
Your ignition switch is definitely screwed. I wouldn't even touch the starter until I fixed or replaced the switch.
Any specific year on the fj60 that seams to be the "one" to get.
I'm thinking new stitch/cleanout of the original is definettly called for. Would a little high pressure air do the trick or should it come apart?
Probably the next thing will be my heating problems. It doesn't get too far before the temp is maxing out. Push it any more than 15 miles at highway speeds and she's ready to blow. I'm temted to just yank the thermostat on this thing, I only drive it in the summer anyway.
any suggestions on how to get this thing cooled down so I can ride a little further to some new territory.
First thing is to try a new radiator cap. Have the one that's on there tested - auto supply shops provide this service, gratis, in my area. Recommend sticking with OEM.
Reverse flush the block (be sure to get the heater out of the loop, first, so you don't clog it), then make sure she's tuned properly (running too lean can cause overheating).
If those don't fix it, DO NOT just yank the thermostat. Instead, test and, if needed, replace the thermostat. It is a necessary part of the cooling system, and running without it will cause more problems than it will solve.
Next step is to pull the radiator, and have it rodded and resoldered. Probably a good idea, anyway, as Toyota radiator tank factory soldering tends to fail, usually at the back edge of the top tank, in my experience. Every Land Cruiser my family has owned (1974, 1978, 1980, and 1982) has failed this way.
I'm waiting for my new OEM radiator in my 1982 to go, now :rolleyes:
HTH
Kirk
Check the teeth on the flywheel for damage. If your missing a tooth or have a few damaged teeth on the gear, it can cause the problem that your having.
What usually causes this is the starter being engauged while the engine is running. When the bad spot on the flywheel is hit by the starter, it can hang up.
If you pull the spark plugs and put the truck in nuetral, you can spin the flywheel by hand, especially if you wear gloves.
This may not be your problem, but I have had this happen to me in the past.
-Stumbaugh
I took a good look at the teeth around the whole flywheel and they looked in fine shape. The lead-in edge wasn't even torn up. it sure did one heck of a job on the starter nose though. Has anyone taken and oval'd out the bottom mounting hole to give it a little more clearance from the starter drive gear to the flywheel ring gear. Just like shimming a older chevy starter to get the right engagement. except it would be moving sideways in an arc instead of down.
