Starter Relay
The EFI relay doesn't have anything to do with the starter turning the engine over. If the engine starts by jumping the starter directly from the battery, then the EFI relay is working. If it wasn't working, the engine would turn over but not start.
When you turn the key to the start position, battery voltage is put on the black and white wire that goes to the neutral start switch. A black and red wire goes from the neutral start switch to the solenoid on the starter. So, step one is to turn the key to start and check the black and white wire at the neutral start switch. If voltage is present, check the black and red wire at the neutral start switch. I'm betting your neutral start switch needs to be cleaned or replaced.
Ignition switch, neutral start switch, solenoid on starter, a black/white wire and a black/red wire. That is all there is in the starter control circuit. Don't go chasing rabbits down any other holes.
THanks for that info. I hope it's not the NSS because those are damn spendy. I pulled the NSS off and cleaned it out a few weeks ago and put some dielectric grease on the contacts. It seemed to work great for about 4 days then started back up. But then again it was really cold out at the time so that may have had something to do with it too. It seems that when it's either hot out or the engine gets hot when I try to start it again is when I have the problem. Thanks again
You can verify that the neutral start switch is the problem by measuring the voltage on both sides of the switch when it is acting up. If you have voltage on the black/white wire, but not the black/red wire, then that is the problem. If you have to buy a new one, I'd first try a used one from cruiserparts.net or some other used parts source. Then as a last resort, buy a new one.
