starter problem
hillbilly desert rat
..hey guys .. when i turn the key the starter takes a second or two to engage ... not always .. then it will catch then turn the key again and it fires up .. then sometimes the starter kind of drags .but she always starts so far that is ... should i just replace the contacts or do i need a new starter ?? battery is less than a year old and the terminals are clean and tight ..
thanks for any info
D
I had similar issues...
Try contacts and plunger, if that doesn't work get a new starter...start small and go larger. If the rebuild fixes it great, if not, try the next thing.
And then you have a new set of contacts and plunger as a spare. Not to make it overly simple.
cool thanks .. i was thinking if buying a used starter from cruiserparts.net rebuilding it and having that installed to ee if that fixed the problem .. have no place to change starter out myself .. used starter is $50 from there..
