Starter or Solenoid
I have a 91 LC. Recently I have had some starting problems and I don't want to just start changing out parts without some advice.
I turn the key and I hear what I think is the solenoid CLICK once. Starter does not engage the fly wheel. This used to happen 3 or 4 times then the starter would engage and fire up the engine on the 5th attempt. It has progressively gotten worse and I had to turn the key about 70 times this morning before the engine fired.
I am assuming that the gas is pumping while I am doing this as it starts very rough as if it was flooded.
Is there an external or seperate solenoid on this vehicle?
Any other ideas on what the problem could be.
(I turned on my headlights and tried to start it to see if it was draining the battery. Negative. My lights stay bright when I turn the key and just get a CLICK)
Help?
I would check your battery connections (I know that is obvious, but quite a few people have found their connections to be poor).
Order new starter contacts and plunger from cdan (there is a nice write up in the FAQs).
Riley
Agreed. Change the starter contacts and plunger. A lot of people don't change the plunger because it costs nearly as much as both contact sets combined and it can normally be cleaned up well with some 400 grit. The hardest part is getting the starter out of truck.
Search for "Intermittent start" and you'll come up with a few threads on the subject. I had this problem but it persisted after the contact/plunger rebuild. Appeared to be the solenoid.
You can do a search, but let me save you some time.
Either replace the starter with a reman from Cdan, or check the neutral switch on the T-case. Both will be revealed in a search.
replacing the plunger and contacts will not fix the issue 99.9% of the time.
