Starter, knock sensor, gasket & misc. part #
Can someone please provide me with the gasket and o ring part numbers for the crossover tube?
2004 GX470
I also have several part numbers I previously could not google foo and figure I will share them.
89615-52010 - knock sensor
82219-60060 - wire harness
82219-60070 - wire harness
17171-50020 - intake gasket
17116-50010 - plenum gasket
22271-50042 - throttle body gasket
23291-41010 - injector isolator
90480-13005 - fuel injector grommet
90301-07024 - fuel injector o ring
2004 GX470
16341-50020 - engine coolant gasket (same front and rear)​
96761-24019 - o ring
96761-35035 - o ring
28100-50101 - starter
For those that care, my 2004 has screw in knock sensors and single pin connectors for each of the knock sensors. These are not harnesses so they are not replaceable. Your only option is soldering in new connectors (90980-11166).
