- Joined
- May 26, 2006
- Threads
- 27
- Messages
- 128
I have a 95 80 115k on it, my initial problem was i would try to start the car and i would get a click and no crank and after a few tries would crank and start. So i decided to replace the contacts on the starter and the solenoid, now after i did that it always cranks however every once in a while i get a grinding noise almost like trying to you shift gears with out pressing clutch in all the way, The funny part is some times it starts right up and sometimes i get that grinding noise. Once it starts the engine runs fine I had a thought that maybe the engine was not turning forcing the starter gears to slip but this seems unlikely being that it runs fine when it does start. Also after the grind noise i let go of the ign switch right away and wait a second or 2 and try again and it will crank a few more times then normal (maybe one or two seconds longer then normal cranking time) but it will start with out any more grinding noise. So before i take the starter appart again i wanted to see if any one had this experience and if anyone had any suggestions.
P.S this is were i got the parts http://www.nationsautoelectric.com/densoparts.html seemed like a reliable source
that's just me...
