Starter Issues I think
I am having starter issues on my 1992 Landcruiser. I jumped in it today, turn the key, lights on the dash come on, but no start, no click no nothing from the starter. Its not a battery issue, I checked it under load. I can see the voltmeter drop just slightly when I turn the switch to the start position. So I have my wife hold the key in the start position while I get into position to start banging on the starter and out of the blue it starts. Drive the thing a few miles turn it off, try to restart it and same thing, turn and hold the key for 10-30 seconds and it starts again. I am kinda baffled, because I dont hear anything clicking in the starter, although I have not been in a real quiet place so I can listen close. I have wiggled the gear shifter that made no difference. The ignition switch does feel just a little bit funny, kida like its binding up just a little. This just seems like a little different problem than the starter contacts that seem to plague the things. Any help would be appreciated.
Look down about 10 posts and you will see another starter thread, sounds like you are in the same boat.
OK, the problem turned out to be the solenoid, but not the contacts. It seems the electromagnet in the solenoid needed voltage on it for about a minute before it would close. I know that the solenoid got very hot before it actually would pull the plunger in..... So if you have a no start problem, and you dont hear the clicks in the solenoid, try holding the key in the start position for a minute or two....It may atleast get you home.
