starter issue
Eastvale, CA 92880
My problem started one day when 97 LC decided not start. We jumped started it thinking that its the battery but it still did not start. Removed the starter and replaced it with a bigger starter from my 94 cruiser. BTW, i dont know what kw they are because all the labels are erased already. I could only tell that my 97 has a small starter and my 94 has a bigger starter. So switching it did not work too. My next suspect was the ignition cut off/theft deterent chip, i really dont know what to call it. So we bypassed that cut off and it got a little better. Now it will still give a problem on the 1st try (will just crank) but on the 2nd try it will start smooth. Its been consistent with no start on first try then it will start on the second try. So my next suspect is ignition switch. Replaced it with a new oem one but still the problem remains. It would have problems on the 1st try then would start with no problems on the 2nd try. I am really out of parts to replace. Any ideas?
When you say it just cranks on the first try do you mean the engine turns over or the starter solenoid just clicks? If it's turning over it sounds more like a fuel pump problem to me.
You need to install a " starter relay ".
Google it, search on mud there's a great write-up on hear.
Solved my problem.
IIRC it looked like a relay come with the ignition switch. Is there another one? Im trying to look for the write up, are you talking about the starter rebuild write up? Thanks.
They are interchangeable. An easy test to see if you need the relay added into the circuit is to hook a wire to the pos terminal on the batt or where it connects to the starter and touch the other end to the spade terminal where the small wire hooks to your starter. If it rolls over right away it's most likely you aren't getting enough voltage to the terminal when you turn the key. You can also put a voltage meter on the wire and see what voltage you get when you turn the key. I'm not really a fan of adding the relay although I did it on my Rx7. On a trail rig it just seems like something else to go wrong.
