Starter Issue after Rebuild
Los Angeles
So a few weeks back I had the starter out while doing the PHH. I have the smaller starter, 2.0kw I believe (has two long screws on the exterior) if that matters.
I had the contacts and plunger from CDAN. Being an idiot though, I mistakenly took the "cap" or whatever covers the end with the brushes off. Managed to push the brushes back and get it back on. Then replaced the contacts and plunger. One of the contacts was longer than the original by a little bit. For instance, one is a crescent shape that is 12mm long (just an example) and the one I got was maybe 14mm long.
Dont know if either of these things would cause a problem.
Anyway, no problems showed up right away. Started right up, everything was good for about a week. Then one morning on a cold (not really cold, maybe 50 degrees) start up, it cranked over once and then BHAM! Just a really loud noise. Dont know exactly how to describe it it. Its like the gear/flywheel engagement, or its about to fire up and doesnt... It usually starts up the next time I crank the engine, but will kind of shudder and start off with low RPM and climb up to 1,200 or so until warm. No other strange stuff going on.
Any ideas? I'm kinda bummed out about it because the whole PHH/Radiator/Starter Rebuild went so well, but now something isnt right. First time it happened it scared the **** out of me. I thought I blew a HG or something, haha, freaked me out.
Thanks!
I didnt clamp the wood down while tightening the contacts. Could this happening because the contacts surface isnt flat?
Been driving around since last September with about every 15th start having problems of bad contacts and a "popping" noise as the contacts arc (I think).
Anyway, finally got around to pulling the starter again a couple weekends ago. Contacts had noticable pitting on opposite edges indicating that they werent installed flush. I lightly sanded the contacts and plunger ring smooth again and reinstalled. I used a hammer and small wood block to make sure they were flush this time, pounding them down after tightening and repeating. Starter problems have stopped, so that was the problem.
Just wanted to post a conclusion to this thread....:meh:
