starter engaging after engine starts
Orange County, California
Just had a bizzare one. Turned key in ignition to start car and what I presumed was the starter (high pitched cranking noise) continuously tried to start the car even after it actually fired up. Turned key off and car still try's to start itself - lasted about 3 mins
Was about to pull the battery but then it all settled down and run fine....
bad starter? solenoid/relay sticking, dirty contacts?
car starts fine now
read this and thinking of pulling the battery anyway until i can check things out in detail
Starter cranking without key in ignition!
Likely the solenoid is sticking. Easy enough to pull the starter and replace the contacts and plunger.
Search and there's lots of threads.
My write up from years ago: Starter Motor Contacts
cheers,
george.
Sounds like selenoid/plunger is sticking. Parts are cheap for the rebuild. And while its out a good time to attack PHH and fuel filter if you havent.
A fire hazard for sure so use caution. Be ready to unhook batt if you must start to go get parts.
