Started missing
North east Indiana
After a round-trip about 30 miles I stopped at a store for 15 minutes and came out to start it and it was running roughly. Had a miss . The engine is a 1985 2F in a 1980 fj40. Now it’s puzzling because it ran super for the 30 miles. Ran smoothly. What would be the first thing I should look at. After driving 5 miles home I pulled spark plug wires to see if the title would change . It got rougher with each one being polled but I wasn’t able to isolate which one was making it miss if that was even the problem. The only thing I did earlier was to accidentally down shift to first from 4th. That made the tires squeak. I was wondering if the timing gears could somehow slip but that doesn’t seem too feasible .
Well needless to say I would appreciate any advice before I start tearing into this 2F motor
Check your spark plugs, I had a similiar issue and there was a hair line crack on one of the spark plugs.
A.J
when i accidently shift from 5th gear to 1st gear in my 83 FJ43L-KC , my clutch-less Direct Drive
Plastic AISIN Fan will sound like and feel like Old The Space Shuttle taking off @ Cape Canaveral when i
was young .......
that being said , i have rattled stuff loose like the Electrical connectors in engine bay and more often
a OEM TOYOTA Vacuum Hose off a Fitting .
im talking Newer Young Fresh 3mm OEM Toyota standard Hoses wit No tension on them freely floating
as they may sorta thing ...........
i would look for a part or component simply Rattled loose or a fastener such as a nut or bolt too
before i would start " Tearing " into your Nice 1985 2F .............
look for obvious and simple fix and issue , its there in plain sight , you just may have not seen it yet ...
good luck , :)
was young .......
good luck , :)
Thanks that’s good advice. I decided on new plugs, roter and cap. First ,( needs anyway), then if still missing I’ll look for loose parts. It’s just strange that it was running so good until I turned it off for 15 min.
exactly , thats why it was a small but catastrophic minor event from down shifting vibration ..
maybe , based on my own personal experience .......... 🤔
But it was running good for 15 miles of my 30 mile round trip after the down shift. So what ever would have happened took time . 15 miles worth of time.
I fix everything and eventually I’ll figure it out but this is a engine I’ve never worked on.
you first need a TAN FJ60 ENGINE 2F FSM OEM Toyota ...........
I’m ignorant on that engine. Would it drop in my 80 fj40 ?
IMO , a 1985 FJ60 2F is a IDEAL Choice for a Minor only / Issue's Free , Minor only / Modification free
plug and Play Install into a 1980 FJ40
it's not really a Conversion IMO , more Modern best of both worlds Update
this is my opinion based on my personal views , im sure others have additional input here too .....
my 83 FJ43L-KC has a NON-USA 60 Series 2F , approx. month is May , year is a 1986 if the SOR.com
chart is Correct ?
my cylinder head does not have air injection Ports , or a 2nd Threaded UNION sensor Port either , to
side of carb ........
but , i do have a OIL Cooler Option , witch puzzles me a bit ?
im sure like anything else , it was made form many Doner Vehicals 🤣
