Started Base Lining the 80 Today
Rock Hill SC
I started this morning at 9am. On the list was:
Valve Cover Gasket
Plug Seals
Intake Hose
Dizzy O ring
Throttle Body Gasket
PVC Hose
PVC
Assorted other hoses
I was surprised because I do not have an FSM yet but, everything went pretty smooth. My thottle body was really in bad shape. I cleaned the valve cover with CARB Cleaner and the throttle body with Throttle Body Cleaner. With the valver cover off, made easy access to the dizzy.
My only hick-up was I put $40.00 worth of plug seals in upside down. SOOO...off to Toyota dealer....could not wait for Cdan to ship. God....$11.40 a piece. Got everthing cleaned and buttoned up by 5pm.
She started right up and purrs like a kitten! Next up is the PHH, coolant flush, cap, rotor, plugs, wires, and brake pads.
Here are some pics from today.
Pics of the baseline
Here are some pics
Glad my power steering pump is on the passenger side. Good job and good luck to you:cheers:
Since you're baselining, you might as well replace the fuel sock in the gas tank.
What goodies did you find in your sock?:)
Gall stones, dirt, calcified pebble looking stuff. To be honest I should have cut it open and expolored but I just looked through it instead.
Big difference in color huh? BTW the rig runs better.:p
That looks good! :) I have used 303 on my rib for years. It is a little spendy, but it is amazing the protection it gives to all types of pvc and rubber, etc. It is not greasy and oily like other protectants.
