start-up question...need help
Have you tested your battery prior to start? Do you get at least 12.5 volts at the battery before start? If you do, then it is your starter that is crapping out, you need the starter repair kit and the plunger.
I did have the same symptons last week and I replaced the contact points and the plunger, now it starts just fine.
Probably the starter solenoid, I had the same problem, but it wouldn't start after 5-10 clicks, it would just keep clicking.
Replaced the starter and it went away.
Starter was about a 1hr job, could of done it faster if I had the open end wrenches to do it..
