Stalled post water cross, why?
Central NJ
Water was up to top of the front bumper, about 150ft long overall. Kept it in Low-low so RPM's were a constant 2K or so. Distributor was dry as (Im pretty sure) were the plugs/plug wires. Was a little wet under there but nothing drastic. Slowly lost power, sputtered, and stalled. Started it back up, ran rough, and was totally normal in 5min. What happened here? I seriously doubt any water got into the motor but something obviously happened. :confused: Did it 2 twice with same results (had to get back out of the area!) This is a 3FE btw...
^^^^^^like they said
Even if you didn't submerge the distributor it is possible for the fan to splash cold water against the cap. This can cause any moisture inside the cap to condensate, resulting in a brief period of rough running until the moisture evaporates again.
Did you check for water in you air cleaner? I choked my 62 once in similar depth, but was going much faster (splashed up into the intake and lost air flow).
I agree with water in cap or cord set, it's certainly happened to me a few times in my day. Additionally, could have taken enough water into intake to cause rough engine while burning off, yet not enough water to do engine damage. I've never anticipated enough stream crossings to justify the cost or appearance of a snorkel, but if you want to keep playing this way, you could consider a snorkel and siliconing the cap & cords.
There's a little hole on the distributor housing itself (not on the cap). It is more like under the distributor and facing straight down. You will need at least a mirror to see the hole. I heard that hole is there for breathing purpose. Some people have decided to JB weld/put a grommet on that hole. Once water goes in the distributor through that hole, the truck will stall. Once it dried out, every thing should be fine. It happens to me every time I enter very slowly into a car wash that has under carriage jet cleaner.
If there's no evidence of water getting in the dist through that hole then you may have other electrical gremlin.
:cheers:
You guys have gotten water into the air cleaner on an '80?:eek: I have made a bunch of crossings over the tires ~3', a couple with water on the hood, have flooded the distributor a couple of times, never a drop in the air cleaner. The 3FE distributor is lower on the motor, making it more of an issue.
The distributor cap is sealed with a gasket, overtime they harden and there is the breather holes in the housing. For sealing the distributor I prefer plumbers puddy, the gray stuff. It doesn't harden, so makes servicing easy, remove the cap, apply a small bead around the bottom. For wires, I use silicone grease on all of the boots, makes removal next time easy and does a great job of sealing.
Thanks for the replies guys. I didnt check the air cleaner cause I figured there'd be no chance of there being water in there given the depth I was in. I guess its possible. Ive heard of this breather in the distributor, perhaps thats what did it. As I said, the rubber dist. cover was bone dry. I will do what you guys suggested but I will be quite nervous the next time. I'd hate to stall IN the water...
On a side note, I did not get ANY water on the inside which was a shock given the bumpers were submerged. The whole thing was pretty cool though. A testament to the capability of these vehicles. Mines stock basically.
Remember, your air intake is just tucked in the PS front fender above the wheel well. Very easy to splash some water up there. I did just hitting a large pool of water one day. Truck sputtered for a little while, but didn't stall. Felt like she wanted to tho.
Snorkel time!!! You know you really want one don't you!
I've had the rough running last time I made some water crossings. Water was probably less than 3 feet, but I was going a little faster than I should have (like the big spashes):D
Anyway, I have a snorkel, so I'm pretty sure it was not water getting in the airbox. As mentioned above I turned it off and let it sit for a while and all went back to normal. Pretty sure it was electrical, sounded like 1 or two cylnders were not firing, but I did not get a check engine light.
I'm planning one sealing up the cap and getting new wires before thenext big trip.
I did search all the "water" threads before posting this initially and did come across some mention of the vent in the distributor. One thing I did read (and agree with) is that the vent must be there for some reason. Im not sure I want to just plug it up and ignore it. Someone said they ran a tube off it similar to the axle breather setups we have. I havent looked at it yet but thats what I would do if feasible.
OK, I have to call BS!:D Buy a snorkel if you want one, they look cool, pull cleaner, possibly cooler air, etc. But in my experience will add exactly zero to the fording abilities of an 80 without the other mods. Breather extensions, etc are needed for the long term life of parts, but won't stop you during a crossing, drowning the ignition will.
In my experience the 1FZ 80 has no problem with bumper deep water and if properly driven, proper bow wave, etc, will ford to edge of the hood height without issue. The risk with hood deep is the unknown factor, if your forced to stop, maneuver, backup, etc and the ignition isn’t sealed the chance of it flooding is very high. This can be a miss or dead motor, while you sitting there waiting for recovery the interior is filling. If you have a snorkel, it will look cool, but that’s all of the good it will do. My guess is that most don’t risk their rig with over the door handle deep crossings and the ’80 doesn’t need a snorkel to do those.
The ’80’s air cleaner, intake is the best that I have ever seen on a stock vehicle, extremely well setup to exclude dirt, water, etc. The intake draws from the highest point under the fender. The fender, well, inner skirt, form an air box, the air/water coming in the front is baffled/slowed by flowing around the headlight, etc and dumps out the back , so the water level is lower than surrounding and splashing, etc is minimal. Then it drawn into the under fender plastic box, my guess is the first cup of splash would sit in there and harmlessly leak or evaporate out after crossing. Next the air cleaner, it a big can, with a centrifugal design, so water would be thrown to the outside and the first cup would go into the tuna can, it has a drain so would drain after the crossing. The air is drawn from the top of the air cleaner, so it would need a bunch of water in it before it would be drawn into the motor.
I would guess that it would take close to a gallon of splash before significant water would be drawn into the motor. I have made hood/door handle depth crossings, have maneuvered in bottom of the headlight depth, have had ignition misses and drown it, but have never seen moisture, mud, etc in even the tuna can. Look at Beno’s pix in the deep water thread I consider that my max depth, to make a rig that will cross deeper will take more mods than just bolting on a snorkel.
Hmm, that set up is much different than in the 62 (intake angled down and forward, direct into the air cleaner with no plastic expansion chamber, easy access for water due to rusted out sheet metal on mine). Wonder if your set up is the same as that on a 3FE 80?
A couple picks of my "swamping", the pic of the air cleaner was taken after the truck pulled itself out, and had partially drained. All this was splash, the truck dropped no deeper into the puddle than you see in the photo. (No K&N in there anymore)
The distributor needs to be vented, if not it will have rust issues. IIRC the 1FZ has 3 holes in the lower casting, a lower drain and two vents. There needs to be some airflow, not much, just enough so the air isn't stagnant. If it's vented with one hose it needs to be relatively large, not vacuum line. I have seen/made several setups like; one line to the air cleaner, the other to under the dash or both to under dash, with one hooked into the an A/C vent. If there is a slightly different pressure on the lines, vacuum line is fine.
Yep some of them are very bad designs, some of the Mazda/Ford cars (probe?) had the intake under the bumper, with no diverter/dump in the plumbing. So a few inchs of water equaled ram water into the motor. I was fun going to the dealer after a rain, rows of them waiting on new motors. Didn't take them long to redesign that deal! Some of the Mini/4runners weren't much better.
IIRC all of the US '80 have the same setup. The big difference is distributor location, lower on the early motors, so more susceptible to drowning.
Yes, that is the same air intake setup as on my 3FE (saw it through the side marker opening when I removed the flare).
Funny that Toyota would put a cover on the top of the distributor when it is the bottom that is susceptible to water.
Tools, thanks for your excellent post. That picture of the air intake also says a thousand words. I've seen several pics of 80's that were dead in the water nose-down on entry. I had pictured the intake just behind the headlight, facing forward, so that a nose-down entry to the water would possibly cut off air flow, stalling the motor. I guessing, now, that they drowned the ignition. Now I can reconnect the hose to my air filter can.
