So I replaced the engine in my 80 a while back and the stupid SRS light has been on since. The error code that I got using the wire trick at the DTC was 31. I tried clearing the code alternating wires to ground at the tc and ab spots as instructed in many posts. I believe i'm doing the sequence right as The light will go off for about 5 seconds. Unfortunately it comes back on. In the FSM the error code 31 is for a faulty airbag assembly unit. I replaced that and tried to reset the code with the same results. any ideas as where to go next. any help would be much appreciated. As the light came on right after changing the engine I'm thinking that the best place to look for a problem would be under the glove box where the cowl wire hooks into the ECU, but I am not sure where the SRS system hooks into the cowl wire. is it before or after the ECU?
