Sr ?
gents,
kindly help me figure out which rivet hole should i use as center reference in making a hole for the rear shackle hanger of the stock leaf springs that i'm gonna use for my SR conversion.
also, i'd like to ask if how am i gonna start with my front pinion drive angle measurement? Is the stock perch should measure 0 degrees before rotating it to get the desired pinion angle after doing the SOA conversion? What's the ideal pinion angle using stock spring in a SOA conversion. by the way, i'm working on a '78 fj40.
your technical advise will be greatly appreciated. if anyone can attached pic or dwg for this query, i think it will be better understanding your advises.
happy new year to everyone!!!
gado
The pinion angle will vary but should point directly at the TC output flange with full weight on suspension. Using a Ujoint at the pinion and a double cardigan (:D ) joint at the TC. Run a search for driveline angles and you'll find lots of info on it.
Search for Shackle reversals and SOAs while yer at it.
Not sure about the rivet hole. Hope it helps.
dont drill till you have your front hanger tacked on. I measured 42" center to center between the two holes for my SOA fj40 with stock springs. the tech links have good info for the SOA.
good luck
