Squeek in rear end?
I have had this intermittently for a long time now it comes and goes but it only make a noise under 20mph and almost always when turning right. Its coming from the back of the truck but I can't track it. Anyone have an idea?
It makes no noise when braking.
I have a squeak coming from the rear under the cargo area from what I can tell. I believe it is one of the bushings. Most likely the sway bar. Might be the panhard. Both have been off in the past 6 months. You might start there and if you come up with a good way to isolate the squeak then let me know. I can only hear the noise mine makes at low speeds on neighborhood streets with the windows down. Doesn't make the noise if I shake the truck in the garage.
-B-
A harmless and helpful way to test this is to take some soapy water in a squirt bottle, squirt it on one bushing at a time and see if it stops squeeking. You'd be surprised what you can track down this way. HTH. :cheers:
I killed 2 birds with on stone and I squirted the likely suspects with WD40. Still squeaks so I've missed something on mine.
-B-
