I have a squeak coming from my 80 that sounds exactly like something is rubbing as the wheel turns around. Sounds like somethign is on the rotor or the brake pads aren't releasing. The problem is that it isn't the brakes and it only makes the sound while in gear. I was coasting down a side street last night and while the truck was not in gear it was perfectly quiet, but if I put it in gear while coasting it started to squeak again and then stopped when I put it in neutral. Is there something with the transmission that might cause this? U-joint that only squeaks with a load on it? This is on an 97 80 with 166k.
Thanks
Thanks
