Forward, no squeak. Neutral rolling backwards, no squeak. Put it in reverse and slowly back up, squeak squeak squeak. Sounds like a squeegee wiping glass every other second. Ideas?
Greased the u-joints this past weekend, rear brake pads and discs are brand new, fronts are low miles on disc and pad.Grease the u-joints
Check brake pads for wear may be the "squealers" on the pads for wear indicators.
Did you properly bed the brakes?Greased the u-joints this past weekend, rear brake pads and discs are brand new, fronts are low miles on disc and pad.![]()
Brakes all bedded correctly, only started squeak while in reverse after I greased the zerks too.Did you properly bed the brakes?
I'll keep this in my list of things to do. Probably not a bad idea anyways since I've only had this LC for a bit over a month and have no clue how often the previous owner ever checked the u-joints.still could be a u-joint that's bad, you would want to drop the drive shaft and check for play or binding in the joint. I grease my joints regularly and still had one go bad due to a blocked passage in the joint, three of the cups and bearings looked like they were brand new, the other that had no grease the bearings were dust and the cup was toast.
