I got a squeak I can’t identify. Sounds like the TO bearing needs adjustment, but it’s got the right amount of play (1/16”). I have the Clutch inspection plate off while running, no contact with the pressure plate. I manually engage via the slave cylinder to make the TO touch, it spins but doesn’t squeak.
it happens in all gears under load when accelerating, pedal fully out. If I press the pedal in it stops. If I’m maintaining speed it doesn’t squeak, only when I put load to accelerate. Idling, neutral, rev engine no noise. It made this sound after I got a new transmission and clutch installed. Started squeaking a few days later. Adjusted the TO and it went away. Had to replace the new Transmission and since the reinstall the noise is back. Read other threads dealing with this noise but didn’t see anything that had the same symptoms.
