'85 4R 22RE
A month or so ago I encountered occasional sputtering at lower RPMs when accelerating from a stop. I believed this had something to do with bad gas, cold weather or something they mix in fuel. The problem has now gotten worse. I have changed plugs, cap ,rotor and checked all the obvious stuff but no solution.
The idle has gotten rough but until the engine warms up the sputtering is not a problem. As soon as I see the temp gauge rise, the sputtering at low RPMs begins. If I take off from a stop and use WOT, the truck accelerates without issues. I think that power overall has decreased, even at highway speeds, and the fuel mileage has suffered.
Has anyone had this problem, or are there any ideas ???
Would a compression/ leak down test be worth the $$
