springs???!!!
I stuck my floor jack under the spring, allowing enough space to mount the plate, and started lifting. POP! Eventually it just popped right in. Bolt up the U-joints and let 'er down. I think you're supposed to tighten the U-bolts while the tires, etc are on the ground, by the way.
Enjoy!
surf
just getting ready to let her down and go thru and tighten everything..than on to the next side...lift installation aint all that bad....things came apart and went back together pretty darn good...i better shut up before i jinx the project...
thanks
osagecruiser
Remember to check your ubolts after this has been driven for a little bit...they will continue to stretch and then finally get tight, and stay that way.
Good luck!
-Steve
Have seen a few folks spring pins shear off from this very thing....
Brand new lift....first time in the woods, broke on the trail....
osagecruiser said:
mill,
seen them shear from what?...loose u bolts?...that would suck!
osagecruiser
Yup, torque them down right, drive a couple hundred miles, torque them again. And maybe once more. My little chicken wings had a hard time getting them tight enough the first time.
