springs and spacers
Crime-free Southwest-Houston
A quick question, the 97 I've bought has a OME heavy lift,gonna look into spacers for just bit more lift and bumpers later. I have read the CC is a must when going over 3". How important is it to get a kit to lower the points where the arms mount to the frame? I'm not gonna go over(at least not right now) 4" of lift but is a kit like that important just haveing 4" of lift? It seems to me one would want to keep the stuff under the truck as high as possible as not to give terra firma the chance to grab any suspension parts. I'm sure this question has been put out there but I'm gonnna ask again. Let me know what ya'll think.
:beer: Tommy
I would start with cc bushings and go from there, once you get over the 3" mark you should get either the slee castor plates or the man a fre drop brackets. If you go over 4 then the slee custom control arms is what you would need.
Cool, thanks I think I will go head and get the CC bushing when I get the spacers. Just to keep things where they should be. Sounds like a good plan. If I go higher later then I'll go w/ the arms. I did things right when I did the SOA on my 55, cut and turn and it rode and steered like a new truck. So... the CC kit seems like the right way to go. I'll post some pics as soon as I can.
:beer:
I'm a little curious, you said the truck came with the OME heavies.
Have you checked to see if the PO already installed the CC bushings?
Boyd
Looked earlier and yes the truck did come w/ the CC bushings. I could see that they are not the stock ones. Also spoke w/ PO nd he said that they were installed w/ the lift. So w/ the spacers and the CC bushings that are in there and see where things are? Or should I plan on the CC plates? Thanks again.
:beer:
