So I have OME J springs, which came with my 94 80. They were obviously a few years old when I got it. It had a slight lean to the driver's at first which has gotten worse over time (7 years). Now it is about 1 inch on the front and 1 1/2- 2 on back. The tags on the springs are long gone, but I suspect they may have got them A verses B sides switched on the installation. I am thinking about swiping the rear springs to see if that helps.
So while I have found and read spring installation instructions, they all assume you are swapping shocks brake lines etc. at the same time. I have, I think, L shocks; and have extended bump stops, brake lines and sway bar drop brackets. Can I just lift the truck and let the axles drop and swap the springs with out removing shocks, brake lines and sway bar brackets. If I have to do all that I think I will just get some new Dobinson's 3 inchers. Any different answer for the front?
