Spring Stiffness
Alpharetta GA
May be beating a dead horse here but was wondering if anyone had switched from ome mediums to heavy's or J's and wanted to know the difference in ride quality. I am about ready to order and don't have any additonal weight on the truck right now and won't until probably late this year to early next year. At that point I will be going with ARB and probably 10k warn with slee step sliders and 295 tires. Anyway getting back to my original question how stiff is the ride with ome heavy's on a stock weight cruiser?:cheers:
Hey, Tommy,
Mine has Mediums up front and Heavies (863s) in the back--I swapped down from the 864 Extra Heavies in the back. All I have in the back, usually, is a drawer system made from 3/4" plywood (unsure of weight--mebbe 150+ lbs.?). While at Slee, we tried Mediums in the back but the truck sat pretty level. After discussing potential loads (camping gear, bike gear, etc.) with Christo, we swapped up to the 863s so the truck has some rake and can take a load better without squatting too far in the back end. That being said, the ride with the 864s was really, really stiff. The 863s are better, but you know you're in a truck when it's unloaded. As for the rest right now--have an ARB up front (no winch yet) and step sliders--kinda down the same path you're going.
Rear springs will probably depend on how much weight you intend to put in the truck. Due to the drawers and intended loads, I opted for the stiffer ride unloaded.
I don't plan to do anything about the front Medium springs until I have more weight on them and see how they deal (winch, dual batts mebbe). So far, they are fine and ride nice with the ARB and step sliders.
BTW--I ended up not buying from WV John--how's your cruiser?
Lugboot,
Thanks for the info. My cruiser is definetley my daily driver so I am trying to keep the ride as smooth as possible. I'm lucky though because my commute is 2.3 miles one way and I usually take a customer's car on my lunch break. Anyway I can't complain about my cruiser too much. List of stuff that was bad as follows: Rear main seal still leaking which he said would be fixed, right front caliper slide backed out of caliper and rubbed inside of my wheel and almost came completely out!, roaring noise from rear of vehicle which I hopefully have pinpointed as a pinoin bearing, rear wiper not working. The good is the engine and tranny pull very strong, the interior is in almost new condition, not one door ding when I got it and the paint is almost flawless, also appear to have been maintained at a dealership, toyota air filter fairly new, fuel filter, trans fluid is good and cherry red, even toyota wiper blades. Still fairly sore over the entire experience but I finally got a cruiser and have to remember it is 10yrs old. Where did you end up finding yours?:cheers:
