Spring Perch angle confirmation???
Washington, DC
Can anyone measure the front spring perch angle for me on a stock FJ55 ? I just measured mine('73), in preps for a SOA on the '72 FJ55 I dont have in front of me, and came up with 3 degrees down towards the front on level ground. It has fairly sagging stock springs...
If this doesnt jive, I will have to measure the 72, but trying to get hte extra housing welded and straightened and built for a drop in, but 3 degrees down in front is a little odd, since my caster is top forward about 2 degrees with this setup, on the 73. so, a little double checking is needed...
thanks in advance!
-Brett
You want stock as in not lifted? If so, I'm out. If lifted but aligned to factory specs is OK, I might be able to help.
