Spring Direction
sykesville,md
Started an SOA on my 76 fj40 last weekend. Cut and turned the axle, installed an Aussie Locker, Longfield 27 spline inners and birfs[used], Ford shock towers, SS brake lines, removed the Rancho 2.5" springs and I am installing stock springs in their place. All my stock springs are marked for each corner but which end goes toward the front? The springs all have 2 wraps or C clips on one side of the center bolt and a single wrap on the other. By wraps I mean the steel that keeps the spring packs together, not the end loops. I think the double wrap is the front for both rear and front springs. Is this correct? Thanks Joeyb
What if I have shackle reversal? I also screwed up my description. The steel bands around the spring packs with rivets holding them to the springs.
Stock Land Cruiser leaf springs will have a millitary wrap, meaning the second leaf in the pack, wraps around the main leaf where the spring would attach to the solid hanger on the frame, shackle reversal does not matter....
Good luck!
-Steve
