spring and shackle bushing question
High Desert, SoCal
I have some after market shackles that I put on my cruiser (stock sua) many years ago. They have a 9/16 pin. At the time I don't remember replacing the bushing. The 9/16 bushings were probably not even available then. (1975) My question is do I need the 9/16 special bushings or can I use the 15mm stock bushings? The 9/16 pin will fit the stock bushing.
Would it be too loose? Would the .028 inches make any real difference?
I have been driving the truck for years. I really don't see a problem, but wanted those with more suspension experience to weigh in.
ID 15mm = .590 inches stock
ID 9/16 = .562 inches aftermarket with 9/16 pin
Thanks Brad
Thanks
Yes I have been there many times. I know what is available. I was asking about whether the 9/16 are actually necessary or if the 15 mm are close enough? I wanted some input from people who have replaced their bushings with poly, have the 9/16 pin and if they used the stock bushings or went ahead and purchased the special 9/16 ones. I wanted to know if the .028 inches difference was all that critical.
