Spool?
I have a question, which will without a doubt, show my noobness.
With a welded carrier, can one drive on pavement without issues?
Thanks,
Ron
No, You will be squealing tires around most turns. Most people would not endure a spool on a daily driver.
The thing I like about welded is you can keep a cheap spare welded up and ready to go. Which reminds me, I need to get one done.
And properly done, you will not have any problems.
And as far as on the street, I am one of the people that don't even like auto lockers on the street. Doubt if I would like a spool. I remember someone saying they liked the spool better on the street as they did not get any surprises like with the auto lockers.
"without issue" is your own interpretation....I personally prefer the spool since it's 100% predictable. Many lockers will lock/unlock at unexpected times and create odd handling characteristics.
ANY time you "load" a locker with power, it locks...and acts identical to a spool. The difference is "unloaded" ie: off the throttle...which, frankly, isn't my driving style ;)
all personal preference...mine sees rare street use, and in a lighter rig like an FJ40, I feel it's streetable...in a heavier FJ45/55/60/etc a welded diff may not be as forgiving...
it helps to air up the tires too...
Mini spools are produced to work with c-clip axles, they are said not to be as strong, but I don't really see how you could break one, but who knows. pictures say a thousand words.
Ford 8.8 mini spool
Ford 9" 40 spliner :) spool
Ford 8.8 mini spool
The mini spool is relying on the strength of the stock carrier assembly, which in some applications leaves A LOT to be desired, opposed to the spool in the lower pic you posted, that is significantly stronger being that it is a one-piece unit that the ring gear attaches to.
:beer:
