SpaceGhost
GOLD Star
- Location
- United States
Posted this last fall, NOW it's coming out and will be available next weekend (April 24th).
SM420/mini reduction/splitcase ToyBox. This was Marlins first production unit, sn # 001. Includes the front side adapter which mates to the sm420 (other tranny side adapters available from Marlin), the mini reduction box with stock low gears (2.8?), tcase side adapter is for the split case only, The tcase is included as well as the following stuff:
Custom output/input shaft for the reduction to split case, part of the original kit.
Stock Toy Mini tcase mount, must be used to support reduction box, and will require fab to build crossmember/skid plate to support it.
Reduction box shifter
Twin stick setup for the split case, custom made, heavy duty, heims on linkage and tight sure shifting.
2 NEW in factory package split case gaskets (since you have to disassemble to install.
Output flanges currently on the tcase are dual pattern round ones from High Angle (probably a stock Toy item), drilled for 4 spd and mini flange patterns.
Shipping on the buyer, and I will build a crate and deliver to Forward Air. If you don't know how this works, the item must be taken to them, weighed and measured then they quote the amount, and only accept Money Orders for shipping. This means you must be able to PayPal me the shipping amount with in 24 hrs so I can go get the Money Order and return to them. You must also make your own arrangements to go to the closest Forward Air terminal and pick it up relatively soon after it arrives. This is the cheapest shipping method available unless you can do prepaid shipping from a shipper that has a terminal in Indianapoilis. I will also drive a a couple of hours to assist buyer in delivery. Trying to make the shipping/delivery as painless as possible, but bigger heavy items are more involved!
Lastly this is sold "as is" with my reputaion hinging on the item being as I stated. I take this seriously, and expect the buyer to be able to meet simple requirements needed to make this smooth. The kit listed at $1400 ish with out the tcase, I am looking for $1000, via paypal prefferably or certified funds. I can take pics once it is out and on my shop bench, there are pics on this site as it went in a little over a year ago.
Replies via E-Mail only please!
