spit the front O2
Hopewell NJ 08525
I noticed a slight Ex leak about a week and a half ago . I could see it coming from under my cat guard when i started it on cold days . I looked under and looks like the gasket between the 2 cats is on its way out again (replaced it last year but had to double it up as the flanges were really thin ) .
While I was looking the nuts on the front o2 were reduced to just a coller not much bigger then the stud and looked like a cone washer slipped on taper up. , didnt get near them as I knew it was not going to stay much longer
I took it out :steer:yesterday and it was getting a little louder , and today I stepped on the gas pulling off from a light and out it popped . Pulled over and unplugged it so it wouldn't melt the pig tail on the cat.( nice o2 flange burn tattoo on my arm :doh: )
Theres no :cool: rumble on a 80 with a exhaust leak :frown:
Hit the few parts stores and no one had a o2 gasket so I hit the Lowes for some SS M8x1.25 nuts since a small leak:hhmm: is better then a 7/8 inch hole right off the header pipe and popped it back in after I shopped around and let it cool off in the parking lot . Of course my wife watched all the horrified soccer moms and metosexual males drive by while I was lying under the truck :wrench:and putting it back in . She got a good laugh out of them .
I know of only one aftermarket supplier (Dorman)for the o2 gasket and no one carries them even when Toyota used this style on just about everything for over 15 years.
Threads on the studs were perfect just needed to tap off what looked like a heil coil stuck to the threads from the old nuts
Oh well off to the local list+20% dealer on monday :crybaby:
Could that cat possible be clogged to blow the gasket? Back in the day the first thing I did when I got a Toyota was to take off the CAT, beat the guts out and bolt it back up, power stealing bastards! ;)
nope the nuts just rotted off since it gets hit with all the road grime,salt and crud as it sits right behind the PS tire wheel well. As for beating the guts out of the cats its seems like the minimal amont of power gain isnt worth the poor running of a ODBII open loop all the time and getting it smogged wont happen up here plus the $$$ I save by not having to pay a big $$$ fine will buy me many cats ;)
There is if your exhaust leak is because the Y-pipe isn't connected.... :lol:
Todd - I've had the same exact thing happen to my front O2 sensor. The thing literally blew itself out while driving (and I can tell you it does then make a rumble when it's completely out and dangling about under the pipe).
I'm pretty sure it happened to me because I reused the old nuts when installing the new sensor about a year earlier. I got some new nuts from James Toyota (they're a few buck for the two of them) and they are definitely not your normal nut. I can best describe them as a sort of crimped castle nut--they bite in pretty well when you're tightening them down which I assume is so they won't back off. I'd replace those SS nuts you got with some Toyota nuts made for this if you don't want to amuse the soccer moms again. :D
