- Joined
- Feb 13, 2006
- Threads
- 36
- Messages
- 464
I have been looking on MUD, Exp portal, Heep forums, etc. for pics and info on what most DIY guys use for supporting their tire carriers. I see lots of ideas, but usually there isn't any follow up regarding how well the system worked (or if it failed)
I have been looking at the various spindles out there (rated from 1000# and up) and also at weld on barrel hinges (rated from 900# per pair to 3000# per pair) I am new to the DIY stuff and really don't have the knowledge to make the proper decision.
Any of you guys have specs on what load rating is required? I want to drive down the road with my new tire carrier and not have to look behind to see if something has sheared off and bouncing down the road!
I can see that the load leverage on the arm is significant, but what is safe and what is not? Clearly the barrel hinges rated for 3000# per pair will do the trick, but money is also a consideration.
Any advice from experienced DIY'ers would be greatly appreciated!
