spindle
I am putting back together the front end of my 1977 fj 40 , I am wondering about this guard that goes over the rotor, it is in pretty bad shape and i would like to be able to throw it in the garbage but I think I need it for a shim between the spindle and the nuckle, do I need this ? thanks
if you look how the guard is designed, you can see that the shim is spot welded in 4-6 locations....a hand grinder and a few minutes of work, and you can remove these and ditch the guard totally.
You'll also need to address the brake hose fittings, there are two hoses listed in Trivia that work for a direct to caliper attachment.
IMO, the guard is a worthless POS and can be tossed, but you do need the spacer and you do need to address brake lines. It is much easier to clean mud from the rotor area without the guard in place. I haven't run one in 4-5 years.
Lines are $20-25 ea, available at NAPA (not stock tho)
