Spindle threads
Reno, NV
I recently purchased my first 80 and I love it, however the previous owners either paid for poor maintenance or did it themselves. I was out Tuesday evening in the hills and my from drivers side tire began to wobble. So I limped home and disassembled it to find no c snap ring, a lock washer split in two (appeared to be very old) and spindle nuts that had walked off the spindle. I am assuming that this was fairly recently done considering the shape of grease and gaskets. Luckily bearings were fine and even more important so were the races. I have a bearing kit and all new hardware being overnighted. The only real big issue is the thread damage on the spindle. Can anyone tell me the size and pitch so I can get the correct dye?
Spindle threads can be cleaned up with a thread file and a little cutting oil. Good luck finding a die big enough. I know they exist somewhere, but they're not easy to find. Likely getting close to the cost of a new spindle.
X2
My guess is 42x1.50mm, there are spindle thread chasers, but they aren't commonly available. If they aren't dorked up badly, a little work with a triangular file or thread file may clean them up, if more damaged than that, time for a replacement spindle.
Thanks for all the input. Looks like I will be purchasing a thread file. I appreciate the help
I don't think a new spindle is in order. I will first attempt to salvage my current. It is only one and a half sereis of threads that are damaged and they are on the very end of the spindle.
