Spindle studs
Bay Area, CA
I'm putting my spindles back on and have run in a couple of studs at 10 and 2 o'clock to help align things. I was going to just leave them there when I bolted it all up to make subsequent owrk easier, but then it occurred to me that they might not be hard enough. I got them from an old axle housing. Anyone know how hard those puppies are? The spindle bolts are 7's, I think. It woudl seem that the 3rd member studs would be tough, too. I've seen the stud kits at Marlin but I don't want to wait - are those studs OEM for later axles? If so, anyone have a year or PN?
Thanks
I do not see what it would hurt leaving two of them studs. You should be fine....
I install the spindle and gasket first on the housing....couple bolts, and seat it with a soft face dead blow hammer.... It stays in place, and you can stack the other goodies on there no sweat.
Good luck!
-Steve
Thanks, Steve, ya, I haven't tried puttng it together yet, just read about people having a pain juggling the parts, and liking the stud kits. But if assembly was THAT bad, Toyoda (or at least the cruiserheads) would have changed to studs sooner!
Thanks for checking in - on this and other posts. I've learned a lot from you over the last couple years!
-James
No worries man...that is what this is all about...
I have learned an awful lot out here too, and not just about trucks.
The hammer trick works well, try it out before you do your final assembly...
post up how it works.
Good luck!
-Steve
