I'm doing a front axle rebuild on a '94 FJZ80. I'm inspecting the spindles and I see two issues:
1. The 54mm lock nuts on the passenger side were very loose and the bearings appear to have spun on the spindle leaving scoring marks. I'm definitely going to replace the claw washer, but I'm wondering if the spindle can be saved. The new bearings don't seem to have play on the spindle. I'm planning to see if the bearings hold preload, or is this an exercise in futility? Any other suggestions?
2. There is also a small grove on both DS and PS spindles from the grease seal. I'm planning to either underdrive the seal leaving it about 2mm proud, or overdrive by 2mm. Thoughts on which is better?
