Spindle bushing symptoms?
Fairfax, VA
Hey all, just replace all wheel bearings and new knuckle kit. I still have a weird noise coming from wheel, it's not clicking like a birfield because I already replaced it. It almost sounds like the center cap on my wheel is rattling. Im thinking its possibly the spindle bushing but not sure. Anyone got any ideas?
:beer:
U Joints or driveline possibly?
I have an odd noise that I'm pretty sure is the splines on my front shaft.
I isolated it by greasing one ujoint then drove and the noise didn't change greased the next u joint, drove and so on then I took my rear shaft off and greased the splines and drove, still noise but when I took the front shaft apart and greased the splines it went away for about 500 miles. After it came back I did another spline greasing and it went away. The noise didn't start until I put the lift on.
I am running 850/863 springs with no additional weight except a second battery. I get my ARB commercial bar and Hanna sliders in a couple weeks, so I'll see if that makes a difference. If not I"ll send Eric at Six States my front shaft for him to cut the ends off and build me a new shaft.
Dave
Dunno if a worn drive flange would make noise or not, did you check them when you had it apart?
-Spike
