On memorial day weekend, when I did my first birf job on my new 80, the driver side brass spindle bushing was messed up when I got it apart. The whole knuckle on that side was dry, birf included.
I called around and toyota local wanted 85 plus shipping to get one in 5 days. Cruiseroutfitters had a few earlier in the week but had just shipped them out. They offered to get me one by early the next week for about 70.00
Bad bushing on newly packed and worked birf.
Pulled out and cleaned. The internal striations are stripped out from being loose and flopping around on the axle inside the spindle.
Called C-Dan. He suggested that the replacement would be about 62., but he also said that the newer spindle's come with a bushing plate and a needle bearing instead of the whole brass bushing. Also, the price was around 47.00 for the new version.
I had re-assembled with the bad bushing to get me by till I could tear back in, and this is what C-Dan's replacement worked out like. Worked great.
I had to use a brass block to get the needle bearing race to seat inside the spindle, then just tapped the brass bushing plate in behind it and back together it went. The spindle is much tighter on the axle now without the play of the burned out bushing.
Thanks C_Dan, great advice as always.
Now that the baselining is done on my 80, it gets it's first road test on Monday Morning. Towing a friends boat about 160 miles to Bear Lake for a few days of freezing the kids on the tube and some fishing.
Baselining to date has included:
Initial price of veh: 4500.00 bad brakes, 4wd/cdl iffy, tires ****
Master Cylinger
DS rear Caliper
Bleeding, bleeding and more bleeding of brakes
Cleaned TB, Plenum, intake.
replaced Injector #6, new seals on all others
Oil Change Mobil 5w30 for now, 15-40 coming next time.
Rear wheel bearings greased, new pads
front bearings packed
front pads (100's) new rotors as well
Birf's rebuilt
trans and t-case checked and flushed (local t-shop)
New Yokohama ATS 285 75 16's
8th seatbelt added
FJammer in dash deck
new 6.5inch speakers in all doors, Mb quart tweets as well.
Washed waxed, polished and fabrezed...
Total investment to date is about 7800.00. Not bad considering that book was 10,100 when purchased in 3/10. 181,500 miles on her as of now.
Bumpers, sliders, 3 inch OME, aussie locker, spare mod, 7 pin mod, and tow hitch relocation coming soon.
Master Cylinger
DS rear Caliper
Birf's rebuilt
8th seatbelt added
